Time Before: 0.00669 seconds
Time After: 0.00959 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00969 seconds
Time After: 0.01019 seconds
Time Before: 0.01046 seconds
Time After: 0.01062 seconds
Time Before: 0.01148 seconds
Time After: 0.01531 seconds
Time Taken: 0.00383 seconds
Time Before: 0.01070 seconds
Time After: 0.02046 seconds
Time Taken: 0.00975 seconds
Time Before: 0.02452 seconds
Time After: 0.02541 seconds
Time Taken: 0.00089 seconds
Time Before: 0.02781 seconds
Time After: 0.02910 seconds
Time Before: 0.02372 seconds
Time After: 0.02935 seconds
Time Taken: 0.00563 seconds
Time Before: 0.04057 seconds
Time After: 0.04072 seconds
Time Before: 0.04784 seconds
Time After: 0.04909 seconds
End call of global.php: 0.050938844680786
Time Before: 0.05448 seconds
Time After: 0.05462 seconds
Time Before: 0.05704 seconds
Time After: 0.05854 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1788920051, location = '/forums/private.php?do=newpm&explain=1&u=31501', badlocation = 1
Time Before: 0.07549 seconds
Time After: 0.07599 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.074349880218506 seconds with 9 queries, spending 0.010224103927612 doing MySQL queries and 0.064125776290894 doing PHP things.
