Time Before: 0.00166 seconds
Time After: 0.00222 seconds
Time Taken: 0.00057 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00230 seconds
Time After: 0.00274 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00296 seconds
Time After: 0.00309 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00383 seconds
Time After: 0.00597 seconds
Time Taken: 0.00213 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00314 seconds
Time After: 0.00949 seconds
Time Taken: 0.00635 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01235 seconds
Time After: 0.01313 seconds
Time Taken: 0.00078 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01691 seconds
Time After: 0.01807 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.01118 seconds
Time After: 0.01826 seconds
Time Taken: 0.00708 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.02365 seconds
Time After: 0.02377 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.02661 seconds
Time After: 0.02823 seconds
Time Taken: 0.00162 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.031377077102661
Time Before: 0.03315 seconds
Time After: 0.03332 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.03636 seconds
Time After: 0.03895 seconds
Time Taken: 0.00260 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=3160'
Time Before: 0.05461 seconds
Time After: 0.05495 seconds
Memory Before: 4,294.781 KB
Memory After: 4,295.031 KB
Memory Used: 0.250 KB
Page generated in 0.053660869598389 seconds with 9 queries, spending 0.0094907283782959 doing MySQL queries and 0.044170141220093 doing PHP things.
