Time Before: 0.00163 seconds
Time After: 0.00233 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00241 seconds
Time After: 0.00277 seconds
Time Before: 0.00298 seconds
Time After: 0.00312 seconds
Time Before: 0.00399 seconds
Time After: 0.00620 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00320 seconds
Time After: 0.00963 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01164 seconds
Time After: 0.01185 seconds
Time Before: 0.01459 seconds
Time After: 0.01578 seconds
Time Before: 0.01084 seconds
Time After: 0.01603 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02242 seconds
Time After: 0.02258 seconds
Time Before: 0.37514 seconds
Time After: 0.37659 seconds
Time Before: 0.37960 seconds
Time After: 0.37972 seconds
Time Before: 0.38210 seconds
Time After: 0.38354 seconds
UPDATE session SET lastactivity = 1788912957, location = '/forums/private.php?do=newpm&explain=1&u=31610' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.39746 seconds
Time After: 0.39782 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
