Time Before: 0.00202 seconds
Time After: 0.00257 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00266 seconds
Time After: 0.00308 seconds
Time Before: 0.00334 seconds
Time After: 0.00350 seconds
Time Before: 0.00430 seconds
Time After: 0.00707 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00357 seconds
Time After: 0.01190 seconds
Time Taken: 0.00833 seconds
Time Before: 0.01377 seconds
Time After: 0.01418 seconds
Time Before: 0.01547 seconds
Time After: 0.01670 seconds
Time Before: 0.01316 seconds
Time After: 0.01694 seconds
Time Taken: 0.00379 seconds
Time Before: 0.02318 seconds
Time After: 0.02334 seconds
Time Before: 0.02511 seconds
Time After: 0.02634 seconds
Time Before: 0.02902 seconds
Time After: 0.02918 seconds
Time Before: 0.03112 seconds
Time After: 0.03293 seconds
Time Taken: 0.00180 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=31615', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04727 seconds
Time After: 0.04757 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
