Time Before: 0.01276 seconds
Time After: 0.01648 seconds
Time Taken: 0.00372 seconds
Time Before: 0.01658 seconds
Time After: 0.01702 seconds
Time Before: 0.01731 seconds
Time After: 0.01744 seconds
Time Before: 0.01821 seconds
Time After: 0.02165 seconds
Time Taken: 0.00344 seconds
Time Before: 0.01750 seconds
Time After: 0.02703 seconds
Time Taken: 0.00953 seconds
Time Before: 0.03600 seconds
Time After: 0.03640 seconds
Time Before: 0.03893 seconds
Time After: 0.04019 seconds
Time Before: 0.03517 seconds
Time After: 0.04046 seconds
Time Taken: 0.00529 seconds
Time Before: 0.05550 seconds
Time After: 0.05563 seconds
Time Before: 0.06582 seconds
Time After: 0.06706 seconds
Time Before: 0.07279 seconds
Time After: 0.07294 seconds
Time Before: 0.07606 seconds
Time After: 0.07750 seconds
UPDATE session SET lastactivity = 1789019818, location = '/forums/private.php?do=newpm&explain=1&u=31662' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09740 seconds
Time After: 0.09780 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
