Time Before: 0.00213 seconds
Time After: 0.00264 seconds
Time Before: 0.00271 seconds
Time After: 0.00339 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00371 seconds
Time After: 0.00391 seconds
Time Before: 0.00471 seconds
Time After: 0.00700 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00396 seconds
Time After: 0.01082 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01256 seconds
Time After: 0.01279 seconds
Time Before: 0.01400 seconds
Time After: 0.01522 seconds
Time Before: 0.01201 seconds
Time After: 0.01539 seconds
Time Taken: 0.00338 seconds
Time Before: 0.02105 seconds
Time After: 0.02121 seconds
Time Before: 0.02329 seconds
Time After: 0.02454 seconds
End call of global.php: 0.026371002197266
Time Before: 0.02753 seconds
Time After: 0.02773 seconds
Time Before: 0.02981 seconds
Time After: 0.03127 seconds
SET lastactivity = 1780654737, location = '/forums/private.php?do=newpm&explain=1&u=31670', badlocation = 1
Time Before: 0.04550 seconds
Time After: 0.04573 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.044560194015503 seconds with 9 queries, spending 0.0079183578491211 doing MySQL queries and 0.036641836166382 doing PHP things.
