Time Before: 0.01958 seconds
Time After: 0.02402 seconds
Time Taken: 0.00444 seconds
Time Before: 0.02410 seconds
Time After: 0.02451 seconds
Time Before: 0.02474 seconds
Time After: 0.02489 seconds
Time Before: 0.02564 seconds
Time After: 0.02804 seconds
Time Taken: 0.00239 seconds
Time Before: 0.02496 seconds
Time After: 0.03397 seconds
Time Taken: 0.00901 seconds
Time Before: 0.04063 seconds
Time After: 0.04099 seconds
Time Before: 0.04370 seconds
Time After: 0.04493 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03993 seconds
Time After: 0.04512 seconds
Time Taken: 0.00519 seconds
Memory After: 2,261.719 KB
Time Before: 0.08056 seconds
Time After: 0.08075 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09388 seconds
Time After: 0.09627 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.10808 seconds
Time After: 0.10835 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11111 seconds
Time After: 0.11264 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=31686', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.12903 seconds
Time After: 0.12928 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
