Time Before: 0.01754 seconds
Time After: 0.02664 seconds
Time Taken: 0.00910 seconds
Time Before: 0.02675 seconds
Time After: 0.02727 seconds
Time Before: 0.02756 seconds
Time After: 0.02767 seconds
Time Before: 0.02857 seconds
Time After: 0.03086 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02775 seconds
Time After: 0.03630 seconds
Time Taken: 0.00855 seconds
Time Before: 0.04769 seconds
Time After: 0.04805 seconds
Time Before: 0.04950 seconds
Time After: 0.05071 seconds
Time Before: 0.04709 seconds
Time After: 0.05095 seconds
Time Taken: 0.00386 seconds
Time Before: 0.07827 seconds
Time After: 0.07843 seconds
Time Before: 0.10401 seconds
Time After: 0.10532 seconds
Time Taken: 0.00131 seconds
Time Before: 0.11482 seconds
Time After: 0.11507 seconds
Time Before: 0.11726 seconds
Time After: 0.11881 seconds
Time Taken: 0.00155 seconds
UPDATE session SET lastactivity = 1784773695, location = '/forums/private.php?do=newpm&explain=1&u=31766', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.14049 seconds
Time After: 0.14078 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
