Time Before: 0.00934 seconds
Time After: 0.01402 seconds
Time Taken: 0.00468 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01411 seconds
Time After: 0.01460 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01482 seconds
Time After: 0.01493 seconds
Time Taken: 0.00010 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01571 seconds
Time After: 0.01769 seconds
Time Taken: 0.00198 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01502 seconds
Time After: 0.02179 seconds
Time Taken: 0.00677 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02616 seconds
Time After: 0.02653 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.02860 seconds
Time After: 0.02980 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.02542 seconds
Time After: 0.03004 seconds
Time Taken: 0.00462 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.04816 seconds
Time After: 0.04828 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.07732 seconds
Time After: 0.07850 seconds
Time Taken: 0.00118 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.09670 seconds
Time After: 0.09682 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.10149 seconds
Time After: 0.10390 seconds
Time Taken: 0.00242 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772947733, location = '/forums/private.php?do=newpm&explain=1&u=31872' WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.12615 seconds
Time After: 0.12654 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
