Time Before: 0.00272 seconds
Time After: 0.00421 seconds
Time Before: 0.00432 seconds
Time After: 0.00477 seconds
Time Before: 0.00505 seconds
Time After: 0.00517 seconds
Time Before: 0.00608 seconds
Time After: 0.00869 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00525 seconds
Time After: 0.01315 seconds
Time Taken: 0.00791 seconds
Time Before: 0.01564 seconds
Time After: 0.01610 seconds
Time Before: 0.01918 seconds
Time After: 0.02053 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01493 seconds
Time After: 0.02077 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02790 seconds
Time After: 0.02804 seconds
Time Before: 0.03097 seconds
Time After: 0.03220 seconds
End call of global.php: 0.033838987350464
Time Before: 0.03568 seconds
Time After: 0.03581 seconds
Time Before: 0.03795 seconds
Time After: 0.03938 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=3188'
Time Before: 0.05401 seconds
Time After: 0.05430 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
Page generated in 0.052836179733276 seconds with 9 queries, spending 0.008206844329834 doing MySQL queries and 0.044629335403442 doing PHP things.
