Time Before: 0.01075 seconds
Time After: 0.01265 seconds
Time Taken: 0.00190 seconds
Time Before: 0.01273 seconds
Time After: 0.01357 seconds
Time Taken: 0.00084 seconds
Time Before: 0.01418 seconds
Time After: 0.01432 seconds
Time Before: 0.01515 seconds
Time After: 0.01760 seconds
Time Taken: 0.00244 seconds
Time Before: 0.01438 seconds
Time After: 0.02221 seconds
Time Taken: 0.00783 seconds
Time Before: 0.02597 seconds
Time After: 0.02631 seconds
Time Before: 0.02910 seconds
Time After: 0.03035 seconds
Time Before: 0.02536 seconds
Time After: 0.03052 seconds
Time Taken: 0.00516 seconds
Time Before: 0.04672 seconds
Time After: 0.04687 seconds
Time Before: 0.05590 seconds
Time After: 0.05714 seconds
End call of global.php: 0.059328079223633
Time Before: 0.06318 seconds
Time After: 0.06332 seconds
Time Before: 0.06578 seconds
Time After: 0.06722 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=31959', badlocation = 1
Time Before: 0.08517 seconds
Time After: 0.08545 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.083955049514771 seconds with 9 queries, spending 0.0082776546478271 doing MySQL queries and 0.075677394866943 doing PHP things.
