Time Before: 0.02191 seconds
Time After: 0.03389 seconds
Time Taken: 0.01198 seconds
Time Before: 0.03398 seconds
Time After: 0.03433 seconds
Time Before: 0.03455 seconds
Time After: 0.03470 seconds
Time Before: 0.03550 seconds
Time After: 0.03745 seconds
Time Taken: 0.00194 seconds
Time Before: 0.03479 seconds
Time After: 0.04239 seconds
Time Taken: 0.00760 seconds
Time Before: 0.05249 seconds
Time After: 0.05285 seconds
Time Before: 0.05527 seconds
Time After: 0.05645 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05185 seconds
Time After: 0.05662 seconds
Time Taken: 0.00477 seconds
Memory After: 2,261.836 KB
Time Before: 0.10068 seconds
Time After: 0.10084 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.12008 seconds
Time After: 0.12132 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.12389588356018
Time Before: 0.13200 seconds
Time After: 0.13215 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.13455 seconds
Time After: 0.13596 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789109083, location = '/forums/private.php?do=newpm&explain=1&u=32061', badlocation = 1
Time Before: 0.15487 seconds
Time After: 0.15517 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.15386891365051 seconds with 9 queries, spending 0.0072250366210938 doing MySQL queries and 0.14664387702942 doing PHP things.
