Time Before: 0.01609 seconds
Time After: 0.02190 seconds
Time Taken: 0.00581 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.02201 seconds
Time After: 0.02249 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.02276 seconds
Time After: 0.02291 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.02372 seconds
Time After: 0.02652 seconds
Time Taken: 0.00280 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.02301 seconds
Time After: 0.03053 seconds
Time Taken: 0.00752 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.03689 seconds
Time After: 0.03737 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.04018 seconds
Time After: 0.04150 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.03615 seconds
Time After: 0.04175 seconds
Time Taken: 0.00560 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.07121 seconds
Time After: 0.07142 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.08801 seconds
Time After: 0.08934 seconds
Time Taken: 0.00133 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.091612815856934
Time Before: 0.09953 seconds
Time After: 0.09967 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.10241 seconds
Time After: 0.10387 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1785419823, location = '/forums/private.php?do=newpm&explain=1&u=32075', badlocation = 1
Time Before: 0.12298 seconds
Time After: 0.12328 seconds
Memory Before: 4,922.375 KB
Memory After: 4,922.586 KB
Page generated in 0.12200784683228 seconds with 9 queries, spending 0.0086541175842285 doing MySQL queries and 0.11335372924805 doing PHP things.
