Time Before: 0.02322 seconds
Time After: 0.03357 seconds
Time Taken: 0.01035 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03369 seconds
Time After: 0.03417 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03445 seconds
Time After: 0.03457 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03552 seconds
Time After: 0.03781 seconds
Time Taken: 0.00229 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03464 seconds
Time After: 0.04328 seconds
Time Taken: 0.00864 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05572 seconds
Time After: 0.05615 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05886 seconds
Time After: 0.06135 seconds
Time Taken: 0.00249 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05498 seconds
Time After: 0.06156 seconds
Time Taken: 0.00658 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.10990 seconds
Time After: 0.11014 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.16090 seconds
Time After: 0.16219 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.19294 seconds
Time After: 0.19308 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.19856 seconds
Time After: 0.20008 seconds
Time Taken: 0.00152 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1768822303, location = '/forums/private.php?do=newpm&explain=1&u=32093' WHERE sessionhash = 'e8e50c90c514c39ba0053dd18b3c9b95'
Time Before: 0.22785 seconds
Time After: 0.22814 seconds
Memory Before: 5,998.531 KB
Memory After: 5,998.750 KB
