Time Before: 0.02778 seconds
Time After: 0.03849 seconds
Time Taken: 0.01071 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03858 seconds
Time After: 0.03903 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03926 seconds
Time After: 0.03956 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.04048 seconds
Time After: 0.04273 seconds
Time Taken: 0.00225 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03962 seconds
Time After: 0.04725 seconds
Time Taken: 0.00762 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.06373 seconds
Time After: 0.06395 seconds
Time Before: 0.06627 seconds
Time After: 0.06746 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06302 seconds
Time After: 0.06770 seconds
Time Taken: 0.00468 seconds
Memory After: 2,261.820 KB
Time Before: 0.11541 seconds
Time After: 0.11556 seconds
Memory Before: 2,815.414 KB
Memory After: 2,815.930 KB
Time Before: 0.14712 seconds
Time After: 0.14836 seconds
Memory Before: 2,903.719 KB
Memory After: 2,904.313 KB
Time Before: 0.16527 seconds
Time After: 0.16545 seconds
Memory Before: 3,540.484 KB
Memory After: 3,540.914 KB
Time Before: 0.16770 seconds
Time After: 0.16916 seconds
Memory Before: 3,822.031 KB
Memory After: 3,823.703 KB
Memory Used: 1.672 KB
UPDATE session SET lastactivity = 1780618621, location = '/forums/private.php?do=newpm&explain=1&u=32139' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.19320 seconds
Time After: 0.19348 seconds
Memory Before: 4,295.875 KB
Memory After: 4,296.102 KB
