Time Before: 0.02043 seconds
Time After: 0.02903 seconds
Time Taken: 0.00859 seconds
Time Before: 0.02912 seconds
Time After: 0.02963 seconds
Time Before: 0.02989 seconds
Time After: 0.03001 seconds
Time Before: 0.03096 seconds
Time After: 0.03333 seconds
Time Taken: 0.00237 seconds
Time Before: 0.03009 seconds
Time After: 0.03744 seconds
Time Taken: 0.00735 seconds
Time Before: 0.04549 seconds
Time After: 0.04589 seconds
Time Before: 0.04854 seconds
Time After: 0.04972 seconds
Time Before: 0.04471 seconds
Time After: 0.04995 seconds
Time Taken: 0.00523 seconds
Time Before: 0.08163 seconds
Time After: 0.08180 seconds
Time Before: 0.10313 seconds
Time After: 0.10438 seconds
Time Before: 0.11309 seconds
Time After: 0.11326 seconds
Time Before: 0.11573 seconds
Time After: 0.11721 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=32173' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.13438 seconds
Time After: 0.13474 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
