Time Before: 0.00513 seconds
Time After: 0.00711 seconds
Time Taken: 0.00199 seconds
Time Before: 0.00721 seconds
Time After: 0.00769 seconds
Time Before: 0.00800 seconds
Time After: 0.00821 seconds
Time Before: 0.00897 seconds
Time After: 0.01202 seconds
Time Taken: 0.00306 seconds
Time Before: 0.00828 seconds
Time After: 0.01576 seconds
Time Taken: 0.00748 seconds
Time Before: 0.01869 seconds
Time After: 0.01912 seconds
Time Before: 0.02149 seconds
Time After: 0.02274 seconds
Time Before: 0.01811 seconds
Time After: 0.02292 seconds
Time Taken: 0.00481 seconds
Time Before: 0.03448 seconds
Time After: 0.03462 seconds
Time Before: 0.03883 seconds
Time After: 0.04047 seconds
Time Taken: 0.00164 seconds
Time Before: 0.04518 seconds
Time After: 0.04535 seconds
Time Before: 0.04770 seconds
Time After: 0.04919 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=32339', badlocation = 1 WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.06259 seconds
Time After: 0.06287 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
