Time Before: 0.01982 seconds
Time After: 0.02557 seconds
Time Taken: 0.00575 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.02567 seconds
Time After: 0.02612 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.02640 seconds
Time After: 0.02656 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.02737 seconds
Time After: 0.02999 seconds
Time Taken: 0.00262 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.02665 seconds
Time After: 0.03381 seconds
Time Taken: 0.00716 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.04500 seconds
Time After: 0.04551 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.04808 seconds
Time After: 0.04925 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.04436 seconds
Time After: 0.04947 seconds
Time Taken: 0.00512 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.08068 seconds
Time After: 0.08084 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.10243 seconds
Time After: 0.10391 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
Time Before: 0.11219 seconds
Time After: 0.11243 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.11527 seconds
Time After: 0.11672 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=32388' WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.13504 seconds
Time After: 0.13534 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
