Time Before: 0.00149 seconds
Time After: 0.00205 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00212 seconds
Time After: 0.00264 seconds
Time Before: 0.00291 seconds
Time After: 0.00308 seconds
Time Before: 0.00394 seconds
Time After: 0.00682 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00314 seconds
Time After: 0.01121 seconds
Time Taken: 0.00807 seconds
Time Before: 0.01317 seconds
Time After: 0.01357 seconds
Time Before: 0.01650 seconds
Time After: 0.01790 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01240 seconds
Time After: 0.01813 seconds
Time Taken: 0.00573 seconds
Time Before: 0.02526 seconds
Time After: 0.02541 seconds
Time Before: 0.02766 seconds
Time After: 0.02890 seconds
End call of global.php: 0.031738042831421
Time Before: 0.03296 seconds
Time After: 0.03311 seconds
Time Before: 0.03628 seconds
Time After: 0.03786 seconds
Time Taken: 0.00157 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=32399'
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.05049 seconds
Time After: 0.05075 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049575090408325 seconds with 9 queries, spending 0.0087606906890869 doing MySQL queries and 0.040814399719238 doing PHP things.
