Time Before: 0.00142 seconds
Time After: 0.00189 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00197 seconds
Time After: 0.00258 seconds
Time Taken: 0.00061 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00285 seconds
Time After: 0.00297 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00385 seconds
Time After: 0.00656 seconds
Time Taken: 0.00271 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00302 seconds
Time After: 0.01018 seconds
Time Taken: 0.00716 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01258 seconds
Time After: 0.01298 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01610 seconds
Time After: 0.01765 seconds
Time Taken: 0.00155 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.01193 seconds
Time After: 0.01782 seconds
Time Taken: 0.00589 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.02304 seconds
Time After: 0.02328 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.02527 seconds
Time After: 0.02653 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.028403043746948
Time Before: 0.02971 seconds
Time After: 0.02996 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.03247 seconds
Time After: 0.03402 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=32455'
Time Before: 0.04788 seconds
Time After: 0.04843 seconds
Time Taken: 0.00055 seconds
Memory Before: 4,294.844 KB
Memory After: 4,295.086 KB
Page generated in 0.047032117843628 seconds with 9 queries, spending 0.0092298984527588 doing MySQL queries and 0.037802219390869 doing PHP things.
