Time Before: 0.01669 seconds
Time After: 0.02576 seconds
Time Taken: 0.00907 seconds
Time Before: 0.02583 seconds
Time After: 0.02633 seconds
Time Before: 0.02658 seconds
Time After: 0.02671 seconds
Time Before: 0.02743 seconds
Time After: 0.03001 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02676 seconds
Time After: 0.03504 seconds
Time Taken: 0.00828 seconds
Time Before: 0.04340 seconds
Time After: 0.04390 seconds
Time Before: 0.04660 seconds
Time After: 0.04788 seconds
Time Before: 0.04263 seconds
Time After: 0.04816 seconds
Time Taken: 0.00553 seconds
Time Before: 0.08098 seconds
Time After: 0.08116 seconds
Time Before: 0.09577 seconds
Time After: 0.09700 seconds
End call of global.php: 0.098955154418945
Time Before: 0.10412 seconds
Time After: 0.10426 seconds
Time Before: 0.10661 seconds
Time After: 0.10807 seconds
SET lastactivity = 1776901741, location = '/forums/private.php?do=newpm&explain=1&u=32571'
Time Before: 0.12653 seconds
Time After: 0.12687 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.125412940979 seconds with 9 queries, spending 0.0083379745483398 doing MySQL queries and 0.11707496643066 doing PHP things.
