Time Before: 0.00184 seconds
Time After: 0.00240 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00249 seconds
Time After: 0.00297 seconds
Time Before: 0.00324 seconds
Time After: 0.00336 seconds
Time Before: 0.00436 seconds
Time After: 0.00694 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00344 seconds
Time After: 0.01160 seconds
Time Taken: 0.00816 seconds
Time Before: 0.01399 seconds
Time After: 0.01419 seconds
Time Before: 0.01702 seconds
Time After: 0.01858 seconds
Time Taken: 0.00156 seconds
Time Before: 0.01327 seconds
Time After: 0.01877 seconds
Time Taken: 0.00550 seconds
Time Before: 0.02398 seconds
Time After: 0.02414 seconds
Time Before: 0.02595 seconds
Time After: 0.02718 seconds
Time Before: 0.03032 seconds
Time After: 0.03047 seconds
Time Before: 0.03251 seconds
Time After: 0.03406 seconds
UPDATE session SET lastactivity = 1788948134, location = '/forums/private.php?do=newpm&explain=1&u=3258', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04638 seconds
Time After: 0.04675 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
