Time Before: 0.00184 seconds
Time After: 0.00234 seconds
Time Before: 0.00241 seconds
Time After: 0.00281 seconds
Time Before: 0.00305 seconds
Time After: 0.00318 seconds
Time Before: 0.00413 seconds
Time After: 0.00690 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00326 seconds
Time After: 0.01219 seconds
Time Taken: 0.00894 seconds
Time Before: 0.01414 seconds
Time After: 0.01453 seconds
Time Before: 0.01749 seconds
Time After: 0.01870 seconds
Time Before: 0.01351 seconds
Time After: 0.01887 seconds
Time Taken: 0.00536 seconds
Time Before: 0.02381 seconds
Time After: 0.02394 seconds
Time Before: 0.02591 seconds
Time After: 0.02712 seconds
Time Before: 0.03024 seconds
Time After: 0.03038 seconds
Time Before: 0.03255 seconds
Time After: 0.03395 seconds
Time Taken: 0.00140 seconds
UPDATE session SET lastactivity = 1789119850, location = '/forums/private.php?do=newpm&explain=1&u=32629', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04633 seconds
Time After: 0.04677 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
