Time Before: 0.02738 seconds
Time After: 0.03428 seconds
Time Taken: 0.00691 seconds
Time Before: 0.03438 seconds
Time After: 0.03476 seconds
Time Before: 0.03503 seconds
Time After: 0.03516 seconds
Time Before: 0.03594 seconds
Time After: 0.03817 seconds
Time Taken: 0.00223 seconds
Time Before: 0.03522 seconds
Time After: 0.04209 seconds
Time Taken: 0.00687 seconds
Time Before: 0.05065 seconds
Time After: 0.05108 seconds
Time Before: 0.05341 seconds
Time After: 0.05461 seconds
Time Before: 0.05001 seconds
Time After: 0.05483 seconds
Time Taken: 0.00482 seconds
Time Before: 0.09760 seconds
Time After: 0.09774 seconds
Time Before: 0.11048 seconds
Time After: 0.11169 seconds
End call of global.php: 0.11399412155151
Time Before: 0.12214 seconds
Time After: 0.12232 seconds
Time Before: 0.12533 seconds
Time After: 0.12679 seconds
SET lastactivity = 1783262550, location = '/forums/private.php?do=newpm&explain=1&u=32685'
Time Before: 0.14354 seconds
Time After: 0.14379 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.14236211776733 seconds with 9 queries, spending 0.0076038837432861 doing MySQL queries and 0.13475823402405 doing PHP things.
