Time Before: 0.02612 seconds
Time After: 0.04277 seconds
Time Taken: 0.01664 seconds
Time Before: 0.04287 seconds
Time After: 0.04328 seconds
Time Before: 0.04355 seconds
Time After: 0.04368 seconds
Time Before: 0.04448 seconds
Time After: 0.04723 seconds
Time Taken: 0.00275 seconds
Time Before: 0.04375 seconds
Time After: 0.05161 seconds
Time Taken: 0.00786 seconds
Time Before: 0.06327 seconds
Time After: 0.06365 seconds
Time Before: 0.06642 seconds
Time After: 0.06764 seconds
Time Before: 0.06263 seconds
Time After: 0.06782 seconds
Time Taken: 0.00519 seconds
Time Before: 0.10758 seconds
Time After: 0.10776 seconds
Time Before: 0.12969 seconds
Time After: 0.13091 seconds
End call of global.php: 0.13317704200745
Time Before: 0.14740 seconds
Time After: 0.14756 seconds
Time Before: 0.15021 seconds
Time After: 0.15164 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=32714'
Time Before: 0.16924 seconds
Time After: 0.16957 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.16799902915955 seconds with 9 queries, spending 0.0082340240478516 doing MySQL queries and 0.15976500511169 doing PHP things.
