Time Before: 0.01615 seconds
Time After: 0.02665 seconds
Time Taken: 0.01050 seconds
Time Before: 0.02679 seconds
Time After: 0.02748 seconds
Time Taken: 0.00069 seconds
Time Before: 0.02774 seconds
Time After: 0.02796 seconds
Time Before: 0.02878 seconds
Time After: 0.03092 seconds
Time Taken: 0.00214 seconds
Time Before: 0.02803 seconds
Time After: 0.03588 seconds
Time Taken: 0.00785 seconds
Time Before: 0.05086 seconds
Time After: 0.05127 seconds
Time Before: 0.05446 seconds
Time After: 0.05569 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05016 seconds
Time After: 0.05596 seconds
Time Taken: 0.00580 seconds
Memory After: 2,261.836 KB
Time Before: 0.08917 seconds
Time After: 0.08942 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10874 seconds
Time After: 0.10997 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.11216282844543
Time Before: 0.12395 seconds
Time After: 0.12416 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.12662 seconds
Time After: 0.12810 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789088377, location = '/forums/private.php?do=newpm&explain=1&u=32775', badlocation = 1
Time Before: 0.14587 seconds
Time After: 0.14609 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.14491081237793 seconds with 9 queries, spending 0.0080900192260742 doing MySQL queries and 0.13682079315186 doing PHP things.
