Time Before: 0.00625 seconds
Time After: 0.00847 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00855 seconds
Time After: 0.00916 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00941 seconds
Time After: 0.00953 seconds
Time Before: 0.01028 seconds
Time After: 0.01271 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00960 seconds
Time After: 0.01653 seconds
Time Taken: 0.00693 seconds
Time Before: 0.02234 seconds
Time After: 0.02280 seconds
Time Before: 0.02617 seconds
Time After: 0.02740 seconds
Time Before: 0.02141 seconds
Time After: 0.02762 seconds
Time Taken: 0.00621 seconds
Time Before: 0.04579 seconds
Time After: 0.04594 seconds
Time Before: 0.05437 seconds
Time After: 0.05561 seconds
End call of global.php: 0.058552980422974
Time Before: 0.06175 seconds
Time After: 0.06190 seconds
Time Before: 0.06506 seconds
Time After: 0.06651 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=32814', badlocation = 1
Time Before: 0.08315 seconds
Time After: 0.08342 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.082118034362793 seconds with 9 queries, spending 0.0080873966217041 doing MySQL queries and 0.074030637741089 doing PHP things.
