Time Before: 0.00158 seconds
Time After: 0.00206 seconds
Time Before: 0.00213 seconds
Time After: 0.00276 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00303 seconds
Time After: 0.00315 seconds
Time Before: 0.00384 seconds
Time After: 0.00654 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00320 seconds
Time After: 0.00990 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01165 seconds
Time After: 0.01211 seconds
Time Before: 0.01463 seconds
Time After: 0.01587 seconds
Time Before: 0.01109 seconds
Time After: 0.01605 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02105 seconds
Time After: 0.02124 seconds
Time Before: 0.02321 seconds
Time After: 0.02445 seconds
End call of global.php: 0.026031017303467
Time Before: 0.02722 seconds
Time After: 0.02739 seconds
Time Before: 0.02935 seconds
Time After: 0.03077 seconds
SET lastactivity = 1783019124, location = '/forums/private.php?do=newpm&explain=1&u=32819'
Time Before: 0.04363 seconds
Time After: 0.04398 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.042213916778564 seconds with 9 queries, spending 0.0085220336914062 doing MySQL queries and 0.033691883087158 doing PHP things.
