Time Before: 0.02679 seconds
Time After: 0.03645 seconds
Time Taken: 0.00965 seconds
Time Before: 0.03656 seconds
Time After: 0.03709 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03737 seconds
Time After: 0.03752 seconds
Time Before: 0.03820 seconds
Time After: 0.04106 seconds
Time Taken: 0.00286 seconds
Time Before: 0.03757 seconds
Time After: 0.04587 seconds
Time Taken: 0.00830 seconds
Time Before: 0.05405 seconds
Time After: 0.05452 seconds
Time Before: 0.05688 seconds
Time After: 0.05807 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05315 seconds
Time After: 0.05827 seconds
Time Taken: 0.00512 seconds
Memory After: 2,261.836 KB
Time Before: 0.09863 seconds
Time After: 0.09875 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.21533 seconds
Time After: 0.21652 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.22923 seconds
Time After: 0.22939 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.23183 seconds
Time After: 0.23329 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788913830, location = '/forums/private.php?do=newpm&explain=1&u=32891', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.25352 seconds
Time After: 0.25394 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
