Time Before: 0.00134 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00233 seconds
Time Before: 0.00255 seconds
Time After: 0.00268 seconds
Time Before: 0.00335 seconds
Time After: 0.00561 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00272 seconds
Time After: 0.00903 seconds
Time Taken: 0.00631 seconds
Time Before: 0.01137 seconds
Time After: 0.01258 seconds
Time Before: 0.01484 seconds
Time After: 0.01605 seconds
Time Before: 0.01046 seconds
Time After: 0.01629 seconds
Time Taken: 0.00582 seconds
Time Before: 0.02218 seconds
Time After: 0.02231 seconds
Time Before: 0.02406 seconds
Time After: 0.02529 seconds
End call of global.php: 0.026968002319336
Time Before: 0.02822 seconds
Time After: 0.02839 seconds
Time Before: 0.03135 seconds
Time After: 0.03287 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=32989'
Time Before: 0.04849 seconds
Time After: 0.04876 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.047543048858643 seconds with 9 queries, spending 0.0085611343383789 doing MySQL queries and 0.038981914520264 doing PHP things.
