Time Before: 0.00132 seconds
Time After: 0.00180 seconds
Time Before: 0.00188 seconds
Time After: 0.00229 seconds
Time Before: 0.00255 seconds
Time After: 0.00275 seconds
Time Before: 0.00336 seconds
Time After: 0.00597 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00282 seconds
Time After: 0.00942 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01108 seconds
Time After: 0.01133 seconds
Time Before: 0.01325 seconds
Time After: 0.01447 seconds
Time Before: 0.01058 seconds
Time After: 0.01470 seconds
Time Taken: 0.00412 seconds
Time Before: 0.01982 seconds
Time After: 0.02006 seconds
Time Before: 0.02171 seconds
Time After: 0.02291 seconds
End call of global.php: 0.024515867233276
Time Before: 0.02555 seconds
Time After: 0.02572 seconds
Time Before: 0.02773 seconds
Time After: 0.02914 seconds
SET lastactivity = 1785374712, location = '/forums/private.php?do=newpm&explain=1&u=33183', badlocation = 1
Time Before: 0.04132 seconds
Time After: 0.04157 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.040432929992676 seconds with 9 queries, spending 0.0079720020294189 doing MySQL queries and 0.032460927963257 doing PHP things.
