Time Before: 0.01920 seconds
Time After: 0.02525 seconds
Time Taken: 0.00605 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02536 seconds
Time After: 0.02615 seconds
Time Taken: 0.00079 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02642 seconds
Time After: 0.02658 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02742 seconds
Time After: 0.02986 seconds
Time Taken: 0.00244 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02665 seconds
Time After: 0.03516 seconds
Time Taken: 0.00851 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04241 seconds
Time After: 0.04284 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04525 seconds
Time After: 0.04645 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04169 seconds
Time After: 0.04669 seconds
Time Taken: 0.00499 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.11501 seconds
Time After: 0.11520 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.18105 seconds
Time After: 0.18231 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
End call of global.php: 0.18445801734924
Time Before: 0.22133 seconds
Time After: 0.22153 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.22817 seconds
Time After: 0.22977 seconds
Time Taken: 0.00159 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=33259'
WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.26050 seconds
Time After: 0.28778 seconds
Time Taken: 0.02729 seconds
Memory Before: 5,997.461 KB
Memory After: 5,997.703 KB
Page generated in 0.2593240737915 seconds with 9 queries, spending 0.035539865493774 doing MySQL queries and 0.22378420829773 doing PHP things.
