Time Before: 0.01917 seconds
Time After: 0.02731 seconds
Time Taken: 0.00814 seconds
Time Before: 0.02744 seconds
Time After: 0.02785 seconds
Time Before: 0.02814 seconds
Time After: 0.02828 seconds
Time Before: 0.02901 seconds
Time After: 0.03097 seconds
Time Taken: 0.00196 seconds
Time Before: 0.02836 seconds
Time After: 0.03544 seconds
Time Taken: 0.00708 seconds
Time Before: 0.04473 seconds
Time After: 0.04515 seconds
Time Before: 0.04816 seconds
Time After: 0.04938 seconds
Time Before: 0.04397 seconds
Time After: 0.04959 seconds
Time Taken: 0.00561 seconds
Time Before: 0.08051 seconds
Time After: 0.08067 seconds
Time Before: 0.10025 seconds
Time After: 0.10147 seconds
Time Before: 0.11551 seconds
Time After: 0.11566 seconds
Time Before: 0.11782 seconds
Time After: 0.11924 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=33279', badlocation = 1 WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.13857 seconds
Time After: 0.13882 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
