Time Before: 0.01487 seconds
Time After: 0.01848 seconds
Time Taken: 0.00360 seconds
Time Before: 0.01857 seconds
Time After: 0.01900 seconds
Time Before: 0.01942 seconds
Time After: 0.01959 seconds
Time Before: 0.02051 seconds
Time After: 0.02304 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01966 seconds
Time After: 0.02745 seconds
Time Taken: 0.00780 seconds
Time Before: 0.03391 seconds
Time After: 0.03411 seconds
Time Before: 0.03724 seconds
Time After: 0.03859 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03322 seconds
Time After: 0.03878 seconds
Time Taken: 0.00556 seconds
Memory After: 2,261.719 KB
Time Before: 0.06187 seconds
Time After: 0.06205 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.18317 seconds
Time After: 0.18440 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.18658995628357
Time Before: 0.19368 seconds
Time After: 0.19388 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.19678 seconds
Time After: 0.19932 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=33303', badlocation = 1
Time Before: 0.21931 seconds
Time After: 0.21979 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.21794700622559 seconds with 9 queries, spending 0.0093152523040771 doing MySQL queries and 0.20863175392151 doing PHP things.
