Time Before: 0.03444 seconds
Time After: 0.04773 seconds
Time Taken: 0.01329 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04786 seconds
Time After: 0.04843 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04871 seconds
Time After: 0.04890 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04965 seconds
Time After: 0.05230 seconds
Time Taken: 0.00266 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04895 seconds
Time After: 0.05635 seconds
Time Taken: 0.00740 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.06922 seconds
Time After: 0.06967 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.07201 seconds
Time After: 0.07317 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.06852 seconds
Time After: 0.07339 seconds
Time Taken: 0.00488 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.12850 seconds
Time After: 0.12866 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.19707 seconds
Time After: 0.19833 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.2006139755249
Time Before: 0.23672 seconds
Time After: 0.23692 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.24511 seconds
Time After: 0.24657 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1768876471, location = '/forums/private.php?do=newpm&explain=1&u=33457', badlocation = 1
WHERE sessionhash = 'e8e50c90c514c39ba0053dd18b3c9b95'
Time Before: 0.27703 seconds
Time After: 0.27736 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.2759268283844 seconds with 9 queries, spending 0.008425235748291 doing MySQL queries and 0.26750159263611 doing PHP things.
