Time Before: 0.00858 seconds
Time After: 0.01145 seconds
Time Taken: 0.00286 seconds
Time Before: 0.01153 seconds
Time After: 0.01209 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01233 seconds
Time After: 0.01245 seconds
Time Before: 0.01325 seconds
Time After: 0.01598 seconds
Time Taken: 0.00273 seconds
Time Before: 0.01252 seconds
Time After: 0.02037 seconds
Time Taken: 0.00785 seconds
Time Before: 0.02522 seconds
Time After: 0.02564 seconds
Time Before: 0.02821 seconds
Time After: 0.02944 seconds
Time Before: 0.02440 seconds
Time After: 0.02969 seconds
Time Taken: 0.00529 seconds
Time Before: 0.05052 seconds
Time After: 0.05066 seconds
Time Before: 0.05998 seconds
Time After: 0.06122 seconds
Time Before: 0.06564 seconds
Time After: 0.06578 seconds
Time Before: 0.06833 seconds
Time After: 0.06986 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=33486' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08507 seconds
Time After: 0.08535 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
