Time Before: 0.00280 seconds
Time After: 0.00347 seconds
Time Taken: 0.00067 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00355 seconds
Time After: 0.00414 seconds
Time Taken: 0.00059 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00432 seconds
Time After: 0.00442 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00508 seconds
Time After: 0.00752 seconds
Time Taken: 0.00243 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00447 seconds
Time After: 0.01292 seconds
Time Taken: 0.00845 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01548 seconds
Time After: 0.01584 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01853 seconds
Time After: 0.01975 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01469 seconds
Time After: 0.02000 seconds
Time Taken: 0.00531 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02853 seconds
Time After: 0.02869 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.03714 seconds
Time After: 0.03837 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
End call of global.php: 0.040098905563354
Time Before: 0.04752 seconds
Time After: 0.04773 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.05046 seconds
Time After: 0.05187 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=33557', badlocation = 1
WHERE sessionhash = '86fb755ccb69fa1491ac644ca6ebf439'
Time Before: 0.06663 seconds
Time After: 0.06688 seconds
Memory Before: 5,998.508 KB
Memory After: 5,998.727 KB
Page generated in 0.065716028213501 seconds with 9 queries, spending 0.0079588890075684 doing MySQL queries and 0.057757139205933 doing PHP things.
