Time Before: 0.00165 seconds
Time After: 0.00288 seconds
Time Before: 0.00296 seconds
Time After: 0.00415 seconds
Time Before: 0.00440 seconds
Time After: 0.00453 seconds
Time Before: 0.00545 seconds
Time After: 0.00765 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00461 seconds
Time After: 0.01241 seconds
Time Taken: 0.00780 seconds
Time Before: 0.01442 seconds
Time After: 0.01486 seconds
Time Before: 0.01825 seconds
Time After: 0.01944 seconds
Time Before: 0.01365 seconds
Time After: 0.01968 seconds
Time Taken: 0.00603 seconds
Time Before: 0.02659 seconds
Time After: 0.02673 seconds
Time Before: 0.02876 seconds
Time After: 0.03001 seconds
End call of global.php: 0.032276153564453
Time Before: 0.03407 seconds
Time After: 0.03423 seconds
Time Before: 0.03768 seconds
Time After: 0.03915 seconds
SET lastactivity = 1788969760, location = '/forums/private.php?do=newpm&explain=1&u=33630'
Time Before: 0.05252 seconds
Time After: 0.05283 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.051592111587524 seconds with 9 queries, spending 0.0084753036499023 doing MySQL queries and 0.043116807937622 doing PHP things.
