Time Before: 0.01181 seconds
Time After: 0.01771 seconds
Time Taken: 0.00590 seconds
Time Before: 0.01782 seconds
Time After: 0.02079 seconds
Time Taken: 0.00297 seconds
Time Before: 0.02108 seconds
Time After: 0.02123 seconds
Time Before: 0.02207 seconds
Time After: 0.02504 seconds
Time Before: 0.02128 seconds
Time After: 0.02987 seconds
Time Taken: 0.00859 seconds
Time Before: 0.03839 seconds
Time After: 0.03874 seconds
Time Before: 0.04123 seconds
Time After: 0.04247 seconds
Time Before: 0.03772 seconds
Time After: 0.04272 seconds
Time Taken: 0.00500 seconds
Time Before: 0.06881 seconds
Time After: 0.06895 seconds
Time Before: 0.09257 seconds
Time After: 0.09383 seconds
Time Before: 0.10508 seconds
Time After: 0.10527 seconds
Time Before: 0.10788 seconds
Time After: 0.10935 seconds
UPDATE session SET lastactivity = 1788869573, location = '/forums/private.php?do=newpm&explain=1&u=33649' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.12715 seconds
Time After: 0.12743 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
