Time Before: 0.02596 seconds
Time After: 0.03274 seconds
Time Taken: 0.00678 seconds
Time Before: 0.03285 seconds
Time After: 0.03340 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03376 seconds
Time After: 0.03391 seconds
Time Before: 0.03479 seconds
Time After: 0.04015 seconds
Time Taken: 0.00536 seconds
Time Before: 0.03398 seconds
Time After: 0.04497 seconds
Time Taken: 0.01099 seconds
Time Before: 0.05385 seconds
Time After: 0.05428 seconds
Time Before: 0.05594 seconds
Time After: 0.05721 seconds
Time Before: 0.05311 seconds
Time After: 0.05741 seconds
Time Taken: 0.00431 seconds
Time Before: 0.10312 seconds
Time After: 0.10327 seconds
Time Before: 0.12335 seconds
Time After: 0.12486 seconds
Time Taken: 0.00151 seconds
Time Before: 0.13555 seconds
Time After: 0.13592 seconds
Time Before: 0.13911 seconds
Time After: 0.14062 seconds
UPDATE session SET lastactivity = 1788878765, location = '/forums/private.php?do=newpm&explain=1&u=3366' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.16297 seconds
Time After: 0.16326 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
