Time Before: 0.01132 seconds
Time After: 0.01767 seconds
Time Taken: 0.00635 seconds
Time Before: 0.01778 seconds
Time After: 0.01826 seconds
Time Before: 0.01856 seconds
Time After: 0.01904 seconds
Time Before: 0.02021 seconds
Time After: 0.02258 seconds
Time Taken: 0.00237 seconds
Time Before: 0.01912 seconds
Time After: 0.02668 seconds
Time Taken: 0.00757 seconds
Time Before: 0.03708 seconds
Time After: 0.03753 seconds
Time Before: 0.04071 seconds
Time After: 0.04196 seconds
Time Before: 0.03623 seconds
Time After: 0.04218 seconds
Time Taken: 0.00595 seconds
Time Before: 0.06191 seconds
Time After: 0.06205 seconds
Time Before: 0.08131 seconds
Time After: 0.08259 seconds
Time Before: 0.09252 seconds
Time After: 0.09270 seconds
Time Before: 0.09536 seconds
Time After: 0.09686 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1788872665, location = '/forums/private.php?do=newpm&explain=1&u=33671', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11312 seconds
Time After: 0.11357 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
