Time Before: 0.01947 seconds
Time After: 0.02627 seconds
Time Taken: 0.00679 seconds
Time Before: 0.02637 seconds
Time After: 0.02681 seconds
Time Before: 0.02709 seconds
Time After: 0.02726 seconds
Time Before: 0.02812 seconds
Time After: 0.03078 seconds
Time Taken: 0.00266 seconds
Time Before: 0.02733 seconds
Time After: 0.03493 seconds
Time Taken: 0.00761 seconds
Time Before: 0.04530 seconds
Time After: 0.04588 seconds
Time Taken: 0.00058 seconds
Time Before: 0.04858 seconds
Time After: 0.04986 seconds
Time Before: 0.04450 seconds
Time After: 0.05007 seconds
Time Taken: 0.00557 seconds
Time Before: 0.09350 seconds
Time After: 0.09364 seconds
Time Before: 0.11669 seconds
Time After: 0.11792 seconds
Time Before: 0.12760 seconds
Time After: 0.12777 seconds
Time Before: 0.13037 seconds
Time After: 0.13185 seconds
UPDATE session SET lastactivity = 1782988590, location = '/forums/private.php?do=newpm&explain=1&u=33679', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.15151 seconds
Time After: 0.15181 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
