Time Before: 0.00135 seconds
Time After: 0.00192 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00199 seconds
Time After: 0.00247 seconds
Time Before: 0.00272 seconds
Time After: 0.00285 seconds
Time Before: 0.00359 seconds
Time After: 0.00781 seconds
Time Taken: 0.00422 seconds
Time Before: 0.00289 seconds
Time After: 0.01259 seconds
Time Taken: 0.00970 seconds
Time Before: 0.01463 seconds
Time After: 0.01490 seconds
Time Before: 0.01659 seconds
Time After: 0.01781 seconds
Time Before: 0.01390 seconds
Time After: 0.01799 seconds
Time Taken: 0.00409 seconds
Time Before: 0.02283 seconds
Time After: 0.02295 seconds
Time Before: 0.02492 seconds
Time After: 0.02617 seconds
Time Before: 0.02909 seconds
Time After: 0.02923 seconds
Time Before: 0.03125 seconds
Time After: 0.03267 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=33698', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04534 seconds
Time After: 0.05564 seconds
Time Taken: 0.01030 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
