Time Before: 0.01640 seconds
Time After: 0.02195 seconds
Time Taken: 0.00555 seconds
Time Before: 0.02203 seconds
Time After: 0.02415 seconds
Time Taken: 0.00212 seconds
Time Before: 0.02442 seconds
Time After: 0.02459 seconds
Time Before: 0.02540 seconds
Time After: 0.02754 seconds
Time Taken: 0.00214 seconds
Time Before: 0.02466 seconds
Time After: 0.03171 seconds
Time Taken: 0.00705 seconds
Time Before: 0.03863 seconds
Time After: 0.03884 seconds
Time Before: 0.04137 seconds
Time After: 0.04254 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03801 seconds
Time After: 0.04272 seconds
Time Taken: 0.00471 seconds
Time Before: 0.08145 seconds
Time After: 0.08161 seconds
Time Before: 0.10173 seconds
Time After: 0.10296 seconds
End call of global.php: 0.10545206069946
Time Before: 0.11634 seconds
Time After: 0.11655 seconds
Time Before: 0.11898 seconds
Time After: 0.12042 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=33937', badlocation = 1
Time Before: 0.13941 seconds
Time After: 0.13969 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.13803291320801 seconds with 9 queries, spending 0.0091204643249512 doing MySQL queries and 0.12891244888306 doing PHP things.
