Time Before: 0.00196 seconds
Time After: 0.00251 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00262 seconds
Time After: 0.00317 seconds
Time Before: 0.00350 seconds
Time After: 0.00363 seconds
Time Before: 0.00431 seconds
Time After: 0.00673 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00369 seconds
Time After: 0.01150 seconds
Time Taken: 0.00781 seconds
Time Before: 0.01360 seconds
Time After: 0.01410 seconds
Time Before: 0.01675 seconds
Time After: 0.01801 seconds
Time Before: 0.01288 seconds
Time After: 0.01826 seconds
Time Taken: 0.00538 seconds
Time Before: 0.02434 seconds
Time After: 0.02456 seconds
Time Before: 0.02723 seconds
Time After: 0.02879 seconds
Time Taken: 0.00155 seconds
End call of global.php: 0.031425952911377
Time Before: 0.03278 seconds
Time After: 0.03296 seconds
Time Before: 0.03592 seconds
Time After: 0.03740 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=34061', badlocation = 1
Time Before: 0.05167 seconds
Time After: 0.05206 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.050698041915894 seconds with 9 queries, spending 0.0086803436279297 doing MySQL queries and 0.042017698287964 doing PHP things.
