Time Before: 0.00135 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00233 seconds
Time Before: 0.00260 seconds
Time After: 0.00278 seconds
Time Before: 0.00366 seconds
Time After: 0.00639 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00286 seconds
Time After: 0.00988 seconds
Time Taken: 0.00702 seconds
Time Before: 0.01178 seconds
Time After: 0.01214 seconds
Time Before: 0.01453 seconds
Time After: 0.01584 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01123 seconds
Time After: 0.01617 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02217 seconds
Time After: 0.02235 seconds
Time Before: 0.02473 seconds
Time After: 0.02600 seconds
Time Before: 0.02912 seconds
Time After: 0.02927 seconds
Time Before: 0.03157 seconds
Time After: 0.03300 seconds
UPDATE session SET lastactivity = 1789056538, location = '/forums/private.php?do=newpm&explain=1&u=3407', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04788 seconds
Time After: 0.04820 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
