Time Before: 0.00871 seconds
Time After: 0.01106 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01116 seconds
Time After: 0.01156 seconds
Time Before: 0.01186 seconds
Time After: 0.01250 seconds
Time Taken: 0.00064 seconds
Time Before: 0.01337 seconds
Time After: 0.01572 seconds
Time Before: 0.01258 seconds
Time After: 0.02000 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02476 seconds
Time After: 0.02514 seconds
Time Before: 0.02779 seconds
Time After: 0.02931 seconds
Time Taken: 0.00152 seconds
Time Before: 0.02407 seconds
Time After: 0.02952 seconds
Time Taken: 0.00545 seconds
Memory After: 2,885.102 KB
Memory Used: 132.781 KB
Time Before: 0.04837 seconds
Time After: 0.04850 seconds
Memory Before: 3,438.195 KB
Memory After: 3,438.711 KB
Time Before: 0.05848 seconds
Time After: 0.05971 seconds
Memory Before: 3,525.867 KB
Memory After: 3,526.461 KB
Time Before: 0.06558 seconds
Time After: 0.06577 seconds
Memory Before: 4,163.750 KB
Memory After: 4,164.180 KB
Time Before: 0.06843 seconds
Time After: 0.06994 seconds
Time Taken: 0.00150 seconds
Memory Before: 4,445.289 KB
Memory After: 4,446.977 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=34161' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.08631 seconds
Time After: 0.08660 seconds
Memory Before: 4,910.688 KB
Memory After: 4,910.930 KB
