Time Before: 0.01157 seconds
Time After: 0.01537 seconds
Time Taken: 0.00380 seconds
Time Before: 0.01544 seconds
Time After: 0.01586 seconds
Time Before: 0.01641 seconds
Time After: 0.01679 seconds
Time Before: 0.01741 seconds
Time After: 0.01944 seconds
Time Taken: 0.00202 seconds
Time Before: 0.01685 seconds
Time After: 0.02331 seconds
Time Taken: 0.00646 seconds
Time Before: 0.02915 seconds
Time After: 0.02954 seconds
Time Before: 0.03144 seconds
Time After: 0.03471 seconds
Time Taken: 0.00327 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02848 seconds
Time After: 0.03494 seconds
Memory After: 2,261.719 KB
Time Before: 0.05365 seconds
Time After: 0.05380 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06630 seconds
Time After: 0.06806 seconds
Time Taken: 0.00176 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.070100069046021
Time Before: 0.07529 seconds
Time After: 0.07550 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07893 seconds
Time After: 0.08040 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=34282'
Time Before: 0.09843 seconds
Time After: 0.09878 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.097429990768433 seconds with 9 queries, spending 0.010427951812744 doing MySQL queries and 0.087002038955688 doing PHP things.
