Time Before: 0.03346 seconds
Time After: 0.04086 seconds
Time Taken: 0.00740 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04104 seconds
Time After: 0.04147 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04173 seconds
Time After: 0.04187 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04255 seconds
Time After: 0.04507 seconds
Time Taken: 0.00252 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04193 seconds
Time After: 0.04961 seconds
Time Taken: 0.00768 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05659 seconds
Time After: 0.05700 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05955 seconds
Time After: 0.06072 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05587 seconds
Time After: 0.06093 seconds
Time Taken: 0.00506 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.13646 seconds
Time After: 0.13659 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.68939 seconds
Time After: 0.69109 seconds
Time Taken: 0.00171 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.69338607788086
Time Before: 0.72957 seconds
Time After: 0.72971 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.73688 seconds
Time After: 0.73844 seconds
Time Taken: 0.00155 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1773314311, location = '/forums/private.php?do=newpm&explain=1&u=34395', badlocation = 1
Time Before: 0.77019 seconds
Time After: 0.77044 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.76917695999146 seconds with 9 queries, spending 0.008450984954834 doing MySQL queries and 0.76072597503662 doing PHP things.
