Time Before: 0.00214 seconds
Time After: 0.00273 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00282 seconds
Time After: 0.00321 seconds
Time Before: 0.00344 seconds
Time After: 0.00360 seconds
Time Before: 0.00446 seconds
Time After: 0.00727 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00365 seconds
Time After: 0.01242 seconds
Time Taken: 0.00876 seconds
Time Before: 0.01506 seconds
Time After: 0.01546 seconds
Time Before: 0.01814 seconds
Time After: 0.01935 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01424 seconds
Time After: 0.01956 seconds
Time Taken: 0.00533 seconds
Memory After: 2,261.719 KB
Time Before: 0.02510 seconds
Time After: 0.02525 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02769 seconds
Time After: 0.02895 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.030664920806885
Time Before: 0.03190 seconds
Time After: 0.03208 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03502 seconds
Time After: 0.03655 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=34408'
Time Before: 0.05224 seconds
Time After: 0.05260 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.051283836364746 seconds with 9 queries, spending 0.0084517002105713 doing MySQL queries and 0.042832136154175 doing PHP things.
